which is better switch bjt or fet ?
ashutosh 123
Joined Feb 26, 2017
38
Hi
To glow an LED which is best as a switch BJT or FET ?
Can anyone help me with reason and circuit diagram for resistor calculation ?
38,927
So what voltage do you have to power the LED?
If you have only 0.8V to control the switch, then a look at the turn-0n characteristics of typical BJT's and FET's will tell you which is better for your application.
ashutosh 123
Joined Feb 26, 2017
38
hi,
Thanks for your reply
But i am not able to distinguish between FET and BJT ? Which should i use to turn on LED?And what are the parameter to chose ?
Thanks again
LesJones
Joined Jan 8, 2017
4,544
Look at the threashold voltage for FETs. Do any meet your input voltage requirements ? What forward voltage is required for the base emitter junction of a BJT to conduct ?
Les.
