Which FET should I choose?
John A Bonilla
Joined Mar 11, 2017
92
Hi Everyone,
I am currently working on a project and am developing a charging circuit. My goal is that whenever I plug the charger into my circuit, the rest of the circuit cuts power and the battery charges. I have done some preliminary research and have come with using a depletion type n-channel mosfet at the positive source of the battery so that when the charge plugs in, positive end is applied to the gate of the mosfet and the power from the battery is cut off. I have the following mosfet in mind:
https://www.digikey.com/product-det...840NH6327XTSA1/BSD840NH6327XTSA1CT-ND/3196629
The charger will be from a USB outlet so it will supply 5V @ 500 mA. If anyone has any suggestions I would appreciate it, and I am open to any questions as well. Thank you!
MaxHeadRoom
Joined Jul 18, 2013
30,890
The enhanced model has a higher rating, I have been using the 2n7000 from its inception and always keep a stock on hand, nice device when used in logic level circuitry.
Max.
John A Bonilla
Joined Mar 11, 2017
92
Max.
Maybe I am misunderstanding the use cases of a depletion vs enhancement type mosfets. My understanding that when an enhancement mosfet is supplied power to the gate, it allows power to flow from source to drain. Depletion is when power is applied to the gate, no power is allowed to flow through the mosfet. Am I wrong?
MaxHeadRoom
Joined Jul 18, 2013
30,890
Well the ones I have used so far (1980's) till now require a gate voltage to conduct, if gate is kept at power common (GND) then no conduction occurs.
Max.
dl324
Joined Mar 30, 2015
18,524
A depletion mode N channel MOSFET is like a JFET. With 0V gate-source bias, it will conduct. You can turn it off with sufficiently negative GS. You can turn on harder by applying positive GS voltage.
