Which clamp meters are the best?
be80be
Joined Jul 5, 2008
2,395
Ones that work LOL just kidding.
It all depends on what your doing how close a reading your looking for.
AC only or AC and DC reading
This is not a bad meter
https://www.coleparmer.com/i/digi-s...uzGG0BLt1oCm2NHLujZVf5PiNSPcQn_xoCKXcQAvD_BwE
This one not bad one too it's cheap but is good little meter just easy to break it
https://www.google.com/search?q=cla...=1280&bih=592&dpr=1.5#spd=1001385110256782556
This is maybe the best starter set you get both
Extech ETK30 Electrical Test Kit with AC Clamp Meter
https://www.google.com/search?q=cla...1280&bih=592&dpr=1.5#spd=13187018499540217864
MaxHeadRoom
Joined Jul 18, 2013
30,699
The old clamp on's where AC only moving coil, I have a a Fluke meter with the Fluke clamp Add-on AC-DC, which works great.
Max.
Reloadron
Joined Jan 15, 2015
7,893
Hi! Which clamp meters are the best?
I guess that really depends on where you are located and what is available to you? We may also consider the range of current to be measured and let's not forget AC or DC or maybe both?
The best clamp on meter would be the one which works best for your intended application and which you have access to and can afford. There, now wasn't that simple?
Ron
