Which battery to use?
Discussion in 'Power Electronics' started by clickman, Dec 13, 2016.
  1. clickman
    Dec 9, 2016
    28
    Hi everyone. I'm involved in a personal learning Project of making a simple audio amp for my Smartphone. I'm using a LF351n that requires a V+ and V- and i've used the virtual ground technique for achieving the voltajes with 2 9V batteries. The thing is that i don't seem to get a proper performance out of the circuit, so i believe the power supply could be the problem.
    My question is what else could i use to power my circuit? I would like to keep it portable, so AC isn't an option.
    Thanks everyone in advance.
  2. Dodgydave
    Jun 22, 2012
    8,279
    1,445
    Post your circuit, and it probably would be better to use higher current batteries.
  3. #12
    Nov 30, 2010
    18,076
    9,691
    The LF351 has a pretty weak output current. If that's all you have, you can barely light an LED, let alone a speaker.
  4. clickman
    Dec 9, 2016
    28
    Wow, i didn't realized that was happening. Should I go for a LM 368?
  5. clickman
    Dec 9, 2016
    28
    This is a very simplified schematic:
  6. crutschow
    Mar 14, 2008
    23,096
    6,850
    An LM368 is a voltage reference.
    You need an audio amp.
  7. clickman
    Dec 9, 2016
    28
    My mistake is that somewhere I saw an audio amp using a 368. What would you suggest me?
  8. #12
    Nov 30, 2010
    18,076
    9,691
    How about an LM386?
  9. clickman
    Dec 9, 2016
    28
    386 yes! but does it need a lot of power? i would like to use portable power.
  10. #12
    Nov 30, 2010
    18,076
    9,691
    The chip doesn't use up power compared to how much the speaker does.
    This is like asking if the steering wheel gets good gas mileage.
    Robert Murphy likes this.
  11. clickman
    Dec 9, 2016
    28
    Great analogy, so this means that maybe i'm too ambitious with trying to drive a speaker with batteries or any other portable power?
  12. crutschow
    Mar 14, 2008
    23,096
    6,850
    For maximum battery life you want a Class D (switching) audio amp such as this.
    It can be powered from three AA or AAA batteries in series.
    cmartinez and #12 like this.
  13. #12
    Nov 30, 2010
    18,076
    9,691
    Millions of, "boom boxes" have been sold. Are you too ambitious to try to do something that has been done so many times before?
  14. clickman
    Dec 9, 2016
    28
    I get it, the thing is that i don't know how to properly do it. my approch is flawed.
  15. clickman
    Dec 9, 2016
    28
    Battery life is very important, but will output be sacrificed?
  16. #12
    Nov 30, 2010
    18,076
    9,691
    Are you kidding? Everything we say, you ask if it makes something else not work.
    Sure, we sit here and give bad suggestions so you will fail, no matter which one you believe.
    Is that what you think?
  17. clickman
    Dec 9, 2016
    28
    No you misunderstood me. I'm new so you should know that i have questions and that I don't know anything, I'm learning and that's normal and also i don't believe that people he want to intentionally misguide others.
    Maybe I should leave.
  18. crutschow
    Mar 14, 2008
    23,096
    6,850
    Sacrificed how?
    Did you look at the data sheet to see if it meets your requirements (which you haven't stated)?
