Which 555 pwm circuit to use? RGB
38,909
crutschow does that circuit need the 4050 to drive a logic level mosfet? I'm trying to keep the component count to a minimum.
No, it will drive a logic-level MOSFET directly at frequencies below 1kHz.
If you use 12V power, it will directly drive a standard MOSFET.
If you use an LM339, which has 4 comparators in a package, one package will do two PWM circuits.
Nealieboyee
Joined May 24, 2017
56
Thanks. I'd need a pull-up resistor at the output wouldn't I? What value?
