Where to put a crystal?
nerdegutta
Joined Dec 15, 2009
2,689
Hi.
I have this schematic, built on a homebrew PCB. I have build some FM minitrasmitters, but they are jumping up and down the frequency.
I also have a lot of crystals, and I would like to use one of them to stabilize the frequency. Is this possible?
rjenkins
Joined Nov 6, 2005
1,013
You need a decoupling capacitor across the power supply. As shown, the battery and it's wiring are part of the RF current path..
Fit a 0.1uF as near to the R7 / L1 power connections as possible. That should help with stability.
Also, if you connect the antenna to a tap on the coil (possibly a quarter of the way down from the positive end), it should be even more stable and give better output.
nerdegutta
Joined Dec 15, 2009
2,689
Hi.
Bertus:
Thanks for the link. Lots of good reading. :) Need to buy some IC's.
RJenkins:
I've edited the schematics, but I'm not sure where to put the 0.01uF near the R7 / L1.
