Hi folks I have the following circuit.
It is driving a set of guide vanes on a turbine but that inst impotent. The motor drives a high ratio reduction box so torque is fairly constant which may matter. Damage to relay contacts is an issue despite using contacts rated at 16A DC
Obviously I cant simply add a diode, as I would have done with a large solenoid.
I don't want o use a MOV as I understand the the failure mod id catastrophic and they degrade with repeated spikes.
Would a TVS and current limiting resistor help between nodes C-D
I am pretty sure an RC network between C-D would help but don't know how to optimise the values.
I also know that typically a switch would have an RC network across it however I have switches effectively between A-C / A-D / B-D / B-C
Can I / Should I add 4 networks? (One on each effective switch)
Would I leave C-D in place if I do?
Am I correct in assuming that damage is most likely as the switch opens, or bounces?
if so would networks B-C / B-D be effective, would C-D still be advisable.
Drowning in options and ignorance here, any and all comments welcome.
Thanks
Al
Thanks
Al
