Where can droop controller be applied?
Mountain_cat
Joined Jul 11, 2016
9
my homework question asks,
Consider three types of distributed generation resources: PV, micro-turbine, and energy storage. Which ones can be controlled by droop strategy? Why?
I thought all of them could be droop controlled since all droop does is synchronize the inverters to the grid. Any help here would be appreciated
SLK001
Joined Nov 29, 2011
1,549
Droop is when demand is greater than the supply. When droop occurs, you need an instant supply to boost the available supply. Which one of your choices can be accessed immediately?
WBahn
Joined Mar 31, 2012
33,111
I think he's trying to point out that PV isn't always available -- probably responded before seeing your later post where you showed you recognized this.
Is "energy storage" always instantly available (instant enough to be of use)? Wouldn't that depend on the nature of the storage?
Mountain_cat
Joined Jul 11, 2016
9
Okay, I guess I misunderstood Alberthall there.
And since this assignment is about microgrids, I guess the energy storage component mentioned is probably ones that are used for that purpose.
Thanks for clearing this up
