Hello all.
I need some help with finding an alternative solution to using a ZSC31050 chip for pressure and force sensors.
Generally the chip functions okay but the limitations that I am trying to get rid of are:
1. Noise
2. The software/programmer/sensor calibration process is not very user friendly.
3. Slow clock frequency 4kHz (I would like to measure maybe 20+ readings per second)
I am currently using it for the 0V to 10V Analog Output / 4-20mA Current Loop with I2C interfacing for programming and calibration purposes. (shown in the application note attached).
The requirements are:
Fairly flexible supply, the wider range the better -> 3-40Vdc
+-0.1% accuracy
operating temp -25/+85C
Zero offset: +-0.2mv/V
Sensitivity: 1mV/v - 2mV/v
resistance 1k -10k
I would really appreciate any help at all.
So far I have looked at Texas instruments PGA900, XTR106u (for the current look application)
but I am not sure if they will be any better?.
If there is no ready made chip available and someone has an Idea of developing something from scratch?
1. Noise
+-0.1% accuracy
resistance 1k -10k
