What's wrong with this LTSpice Sim? -- NMOS and PMOS in SineWave
ci139
Joined Jul 11, 2016
2,018
TEST::correct text would be "... filetype<colon>pdf ..."
(is the year 2016 on that very webpage)
dl324
Joined Mar 30, 2015
18,449
Question about FETs
Since you're learning about MOSFETs, you should get yourself into the habit of using the correct terminology. FET is the general type. It would be helpful to specify the specific type of Field Effect Transistor you're referring to avoid confusion.
Some are: MOSFET (enhancement or depletion mode), JFET, IGFET, MESFET, ...
Depletion mode MOSFETs and JFETs are on with no gate bias.
