What's in a USB memory stick?
Alec_t
Joined Sep 17, 2013
15,156
An old USB1 memory stick died, so I was curious to see just what was in it.
One side of the pcb contains the main 2GB memory array (a Samsung chip)
The other side contains the micro (U3), together with its crystal (U6), for doing the housekeeping. There is also an unpopulated space for another memory array.
Amazing. No doubt a more modern stick would be even more impressive.
dl324
Joined Mar 30, 2015
18,455
All NAND FLASH storage devices need to have a microcontroller to implement ECC, bad block marking, and wear leveling. To keep the FLASH devices inexpensive, they have to tolerate manufacturing defects.
The innards of a 64GB MicroSD card would be interesting to see.
Marley
Joined Apr 4, 2016
519
What is interesting is that your 2GB memory chip contains 2G = 2,147,483,648 bytes. Or 17,179,869,184 bits (approximately).
How much chip area is available for each bit? Don't forget a lot of the chip area is used for interconnections and decode/programming logic.
And 2GB is fairly small by today's standards!
