What's function of PCE164P-N06 Card?
Discussion in 'Computing and Networks' started by Jon325, Feb 8, 2019.
  1. Jon325
    Feb 8, 2019
    SORRY TO INTERUPT.
    I'm Jon, I'm ignorant about electronics for the most part. I need someone to I'd a part for me. Not sure what it is or it's for. Please help
    Mods Note:
    Please hijack other member's thread.
    This thread was split from Seeking help for component selection. Arduino Heater Control : current 10A, system voltage 12V DC.
  2. Jon325
    Feb 8, 2019
    What is it for?
  3. KeepItSimpleStupid
    Mar 4, 2014
    3,542
    669
    Whatever it is, its missing the key component.
    It has:
    SATA
    USB
    Standard Power connectors: https://www.amazon.com/COMeap-3-Pack-Express-6-inch-15-5cm/dp/B01M348RBC
    Likely the rest is a switching regulator to get to a lower voltage.
    And a PCIE card edge connector, which is a small form factor Bus.
    It's missing the CPU, SATA and USB interfaces which would plug into the edge connector. You have the connectors for the SATA dive, USB and power to and from the hard drive I would guess.
  4. shteii01
    Feb 19, 2010
    4,667
    745
    mining cryptocurrency
  5. LesJones
    Jan 8, 2017
    2,303
    692
    If you put "PCE164P-N06" into a search engine (I used DuckDuckGo.) you will get many hits. This is the first one which should tell you what you want to know.
    Les.
  6. tawm
    Feb 8, 2019
    10
    7
    Like shteii01 said, these are mostly used to add large amounts of graphics cards to a system for cryptocurrency mining.
