Check the test conditions in the datasheet.please tell us what voltage we should we apply to diode for it's reverse (leakage) current test?
and how can we confirm that the diode is ok or not after result.
same way also tell for forward current test of diode?
in data sheet so many perameters given for volt & current both, so will u please tell me which we have 02 (volt & current) perameters we have to select for reverse current test & which 02 perameters for forward test?Check the test conditions in the datasheet.
diode is not in circuit, test is to be done for screening of components before soldering it to circuit.You apply either the voltage the diode sees in your circuit, or the (hopefully larger) rated voltage of the device, which ever makes the most sense for your use.
When you apply the voltage measure the current. A reading low enough to meet the spec means the device passes that test. Reject any parts that read above the maximum.
The test is non destructive when the reading is within spec.
Additional testing should be done to confirm you do indeed have a diode and not an empty box.
in short pl. tell me if u know, from data sheet of corresponding diode no matter low or high voltage diode, which voltage & current should we refer for reverse as well as for forward test?Check the test conditions in the datasheet.
In the datasheet,there is forward current vs voltage graph. And there is some reverse current (max) at some given voltage. If the test was done at AC, then the results would be rapidly flipping between forward and reverse so that is not a good or easy way to get a result, is it.in data sheet so many perameters given for volt & current both, so will u please tell me which we have 02 (volt & current) perameters we have to select for reverse current test & which 02 perameters for forward test?
also in data sheet it is not given ac or dc volt to be supply ? also clear this too.
attached is the diodes data sheet & i have 'capacitor input (pai) filter 0 -230 volt & 04 amp. dc power supply' with suitable volt & amp. meter also having LCR multimeter.Post your device specification data sheet and I will point these out to you.
attached is the diodes data sheet & i have 'capacitor input (pai) filter 0 -230 volt & 04 amp. dc power supply' with suitable volt & amp. meter also having LCR multimeter.In the datasheet,there is forward current vs voltage graph. And there is some reverse current (max) at some given voltage. If the test was done at AC, then the results would be rapidly flipping between forward and reverse so that is not a good or easy way to get a result, is it.
So, assuming DC.
As for exact values, any reasonable number can be used for your experiment, the point is, you only have a reference to compare to if you use the same as in the datasheet.
I cannot help you find the number used in the datasheet because you have not posted the part number you are using or the datasheet for the part.
This datasheet is for a whole series of diodes. Which specific diode do you have? Or, is your part number a secret that we have to guess?attached is the diodes data sheet & i have 'capacitor input (pai) filter 0 -230 volt & 04 amp. dc power supply' with suitable volt & amp. meter also having LCR multimeter.
part no. is 320UMR60.This datasheet is for a whole series of diodes. Which specific diode do you have? Or, is your part number a secret that we have to guess?
part no. is 320UMR60.attached is the diodes data sheet & i have 'capacitor input (pai) filter 0 -230 volt & 04 amp. dc power supply' with suitable volt & amp. meter also having LCR multimeter.
I'm a bit concerned for your safety, working with hundreds of volts and asking questions like this do not make me confident that everyone will still be healthy tomorrow.part no. is 320UMR60.
it concludes like these ~The 320UMR60 is the 600 volt device. Look at the ELECTRICAL RATINGS table. The max voltage (Vrrm) is spec'ed at 600 volts. The max reverse current (Irm) is spec'ed at 12mA.
So apply 600 VDC and read no more than 12mA.
Forward voltage (from ELECTRICAL SPECIFICATIONS) specs the max forward voltage (Vfm) at 1.65V when the max forward current (If) of 320 amps is applied.
A 230 volt 4 amp supply can do none of these tests, though you could use it to do a less stringent test: a part that fails Vrrm at 230 volts or Vfm at 4 amps cannot pass the higher limits.
pl. refer attached data sheet for part no. 320UMR60 for which the same part is to be test for it's screening purpose before fix in to the circuit.The answer depends on how the reverse current is specified or your particular applications requirement.
