So I finally got the wiring figured out and it will work (from this post).
Here's the run down: In the pic below you will see 2 sets of 5 pins each, for a total of 10 pins under where it says "CL". There is a red jumper that jumps in between each set, only one set can be connected at a time.
I will be running an individual wire to each pin, and then to a switch in the NEMA 4 enclosure, which has a round cut out of about 1/2" (.475" to be exact). I need this to be a rotary switch that, with each position will connect only 2 pins (the jumper normally would do this). So I am thinking I need something like a 5 pole, 1 throw rotary switch, is this correct?
