What type of Phase converters is this?
MISTER T
Joined Aug 2, 2017
8
So I bought a phase converter a few months ago (second hand) and have been using it just fine with the motor it came with. I have changed the motor the other day and it still works fine but i found a video talking about rotary phase converter and it made me think if I have a rotary converter and have been using it wrong or if it is a static converter?
I can't see anything saying what it is so i am hoping someone can tell from the pictures.
Thanks for any help you can give
MISTER T
Joined Aug 2, 2017
8
Thanks for the reply
that is what I thought but best to check.
One last question is it possible to convert this into a rotary early or not just thought I'd find out in cases i need to at some point
MaxHeadRoom
Joined Jul 18, 2013
30,885
If it includes a motors that points to a RPC version?
Static convertors do not normally have a transformer, the switching is done electronically but is there no make/model #?
Max.
MISTER T
Joined Aug 2, 2017
8
Max.
I should note that the is only one wire going to the motor with the 3 phases and the earth there is no wires coming back and it doesn't look like the ever has been.
Like I said in the first post it fires and runs the new bigger motor fine under loud so I don't know what to think or do
MISTER T
Joined Aug 2, 2017
8
Is there some way to test what it is like if I put a voltmeter on the phases when it fires up should one phases have no power until it is running?
Or something like that?
