How long are the cables?
Are the 6 conductors in a jacket, without other conductors, or are the discrete wires lashed up with all sorts of other conductors in a bundle or ... ?
Are these fine-stranded wires or just the usual in the range of about 7 to 20 strands?
If all the strands are broken and only fully separate on flexing, is it safe to run the robot or will it break things? If a wire fault were detected on a running robot, is there any easy way to use a signal from the detector to stop the 'bot before it goes berserk?
Can you tell us any details of the nature of the signals in the wires? What magnitude of currents? Voltages?
Would a box that you plugged in at one end between the cable and ??? for testing be acceptable? i.e. the box installed in-line but designed so it doesn't interfere with normal operation
I want to try to calculate what sort of resistance difference you would get for a wire with some broken strands. The wires are fairly small and an added fraction of an ohm caused by broken but touching strand ends might be a very small percentage of the normal total end-to-end resistance.
I'm also thinking in terms of some sort of way to detect transient interruption of the signal by sensing current in the wires, or something like that. You would have to cause the flexing that would cause loss of continuity and if that can't be done manually (presumably not, or you'd be doing that way already), then the robot would have to go through the motions.
