What materials do i need to start my first circuit board project?
DJG2011
Joined Jul 23, 2011
4
i want to start my first project, i have all the tools but what materials do i need, all i want to make is a simple circuit board with a LED on it that lights up when i press a button, so what is everythink i need meaning what type of circuit board and and LED lights ect. ect. because im a complete noob ;) so EVERYTHNK i need to do it
thanks -josh
maia31
Joined Jul 20, 2011
6
well
first of all is wire:)
then breadboard
third is voltmeter or ohm meter
and diode
and if you don't have any dc power maby a battery
sorry for may bad eng
debjit625
Joined Apr 17, 2010
790
1)LED (Red one)
2)470 ohms resistor
3)9V battery
4)Push switch.
If you want to do it in breadboard(a board where you can insert your component with soldering)
1)Breadboard
2)Some wires suitable for your breadboard
If you want to do it in Veroboard.
1)Veroboard
2)25 to 30 watt soldering iron
3)solder (use 60/40 rosin core)
I dont think you want to make a PCB for this circuit...
Good Luck
Wendy
Joined Mar 24, 2008
23,838
Depends on what you mean start a circuit board. Here is an article I haven't finished yet.
Prototyping Electronic Circuits
If you ever want to make something really fancy (warning, this is the advanced method)...
How I make PCBs
The AAC book has a Volume devoted to this, see the link on top (Volume VI). It will cover tools and materials, techniques and projects. It is worth a read.
