What is use of R41 (base to emitter) resistor in Transistor Relay Circuit ?
zastereo
Joined Jun 6, 2018
I am controlling relay from arduino, using following circuit.
I want to understand what is use of R41 (base to emitter) resistor ?
Is it required for base termination ?
How to calculate it's value ?
#zastereo
27,361
The base to emitter resistor is required to assure that the transistor switches off when the opto-isolator switches off. It also serves to shunt any leakage current from the opto to common, so that the transistor will be completely off. The value of the resistor needs to be low enough to assure that the combined leakage currents will never bring the base voltage high enough to turn the transistor on at all. It must also allow any stored charge on the base to be quickly drained, so that the transistor switches off quickly.
zastereo
Joined Jun 6, 2018
How to calculate the appropriate value ?
It also forms voltage divider to base of transistor ?
#zastereo
danadak
Joined Mar 10, 2018
4,057
Calculate total leakage from Q1 + Optooutput, then R ~= Vbe / Itotleak.
It does create a divider but normally high enough value that it does not
impact driving Q1.
Regards, Dana.
27,361
Both Dana and "DAD" are correct. The base is current driven, R3 must allow enough base current for the transistor to saturate, at which time the Vbe will be around 0.7 volts. So to calculate the values of the 2 resistors, you need to start with the collector current required for the relay, then determine the base drive to fully saturate the transistor for that current, and then determine the R3 value to assure that there is adequate drive once the voltage drop in the opto-isolator is known for that current. That is why most designers would first choose a value for R4 that they like, instead of doing the calculations. Some circuits are not as critical as others, unless you would be striving for the absolute minimum power use.
