You may not be able to unless other components are changed to avoid over-voltage or over-current problems.How increase it ranges to 16V?
A normal PSU has a lot of protection built in - Over Voltage and Under Voltage protection for 5 and 12 volts, and Current Limit. But it can be done, and has been. Take a look at thisYes it adjust 12V out put but the range is from 10.5V to 12.5, How increase it ranges to 16V?
It uses a KA75008 chip, which uses pins 1+2 and 15+16 as reference inputs to compare and adjusts the output. The preset will adjust one of those inputs and will probably increase in resistance to increase the output voltage, ideally you need to reverse the circuit diagram to see what the other inputs are doing, any shutdown is usually on pin 4, by pulling it high, putting pin 4 low keeps it running.Yes it adjust 12V out put but the range is from 10.5V to 12.5, How increase it ranges to 16V?
