What is this MOSFET?
magnet18
Joined Dec 22, 2010
1,227
I was taking apart the tv I'm getting parts from for my plasma speaker, and I found what i think is the MOSFET that drives the fly-back.
I was trying to find the specs for it and after about half n hour of searching i couldn't find the datasheet, just tags of it in other sheets that said nothing about it.
Its labeled D1556, I attached a pic.
Anyone know where I could find the specs for this?
kkazem
Joined Jul 23, 2009
160
Hi all,
Yes, this is almost certainly a 2SD1556. This is a Japanese (actually, far east in general) numbering system for semiconductors unlike the US JEDEC Standard Part Numbering for Diodes & Transistors (1NXXXX, 2NXXXX).
The Japanese started the 2SAXXXX, 2SBXXXX, 2SCXXXX, & 2SDXXXX numbering system back in the 60's I think and most far-east products use these to this day. Note that it doesn't include ICs. The markings are almost always the part number with the 2SY left out, where the Y is the first letter after the initial characters 2S.
Of course, there are always exceptions. For example, a house-marked transistor. This is where a company like ON-Semi will mark the part with any number you want, other than a standard part number. I don't know if that goes for Far-East transistors and Diodes or not. Anyway, since the far east parts leave out the 2S, the rest is probably fair game. This is often done for two reasons. First, to throw off competitors trying to reverse engineer a design and the other reason is that a firm may have a special part numbering system and they prefer to have all their semi's marked with their own part numbers, at least wherever possible.
Regards,
Kamran Kazem
kkazem
bertus
Joined Apr 5, 2008
23,026
The transistor will work fine on lower voltages for Vce.
The 1400 Volts is a test condition.
The Hfe is tested at a Vce of only 5 Volts.
marshallf3
Joined Jul 26, 2010
2,358
Revise your schematic to indicate a true 2SD1556 and it needs some current to drive but not much Vbe.
All around one of the best horizontal output transistors made for that frequency but heat sink it with a thick mica washer & plenty of thermal grease or it'll try to arc back. They are not bulletproof. Find an old TV schematic where one was used.
magnet18
Joined Dec 22, 2010
1,227
arc back?
:confused:
debe
Joined Sep 21, 2010
1,419
Since there is a huge amount of different Horz O/P transistors the chance of finding a TV circuit with a 2SD1556 transistor init is going to be remote especialy if it was in a monitor. But most Flyback? Horz O/P circuits are basicly the same. I will post several TV Flyback circuits.
