What is this metal wire for?
nickyland96
Joined Nov 28, 2023
hi im trying to bring back to life a spherex 5.1 Xbox surround sub and im looking at the circuit for the power supply and noticed a couple metal wires on the board and one had a little corrosion and i scraped it offelectronic-circuit-board-close-up-2JDCX43.jpg and it looks broken does any one know what this is? there circled in pink
Ya’akov
Joined Jan 27, 2019
10,244
They are just links to join the circuit tracks together, it might have been a modification.
Since the silkscreen shows line, and the resistors are called out in their markings, I am going to say this is an older PCB, single-sided, and the designer wanted to treat it as double sided, hence the jumpers—probably avoiding traces on the reverse.
Ya’akov
Joined Jan 27, 2019
10,244
Yes, they are jumpers, quite common on single layer PCBs.
The only other use I have seen of such jumpers (aside from deleting optional components like attenuating resistors) is a somewhat bigger version as a burden resistor for current sensing.
