What is this good for (12v in 12v out)
dmtamsen
Joined Jul 15, 2018
12
On my boat I have a 24v to 12v converter and from the 12v out it goes into this circuit, left connector, and the from the right connector i used to get 12v (but an 10 ohm resistance has be burnt and some thing else, that something I don’t know what is)
I possible I need help with two things,
1: why is this circuit needed
2: anyone that can help me identify the burned components :)
Thanks in advance.
Dennis :)
dmtamsen
Joined Jul 15, 2018
12
Welcome to AAC!
A diode and the other looks like a resistor.
It would be helpful if you marked the components in question so we can be more certain about what you're referring to.
I think you got it, the two components that have visible burnt black surface around them:)
ebp
Joined Feb 8, 2018
2,332
The burned part near the big transistor was almost certainly the same as the one that isn't burned on the other transistor - a 10 ±5% ohm power resistor that looks very like a Philips PR02 2 watt metal film.
The one near the small transistor looks like it was a diode. My guess is it was an ordinary silicon diode rated at 2 to 3 amperes, but there is some chance it was a zener-type transient suppressor or an ordinary zener dode. You might be able to read at least part of the part number if you remove it from the board.
I would check all of the transistors, looking for short circuiting.
Note the small resistor (red red something gold) below the transistor below the fried diode has been overtoasted. It may be OK
The circuit is probably just a fairly ordinary linear voltage regulator.
dendad
Joined Feb 20, 2016
4,641
It could be a good exercise for you to trace the circuit out.
This should not be too hard to do as it is all visible, and it will help you understand the circuit function.
dmtamsen
Joined Jul 15, 2018
12
Any idea why this is added just after the 24v to 12v converter ?
I have instruments (all 12v) being powered from the converter directly and others from the output from this circuit.
What I cannot understand is why is this needed, why not just power all instruments directly from the converter.
I understand that looking up BD249a will give me some clue of why, but the totally newbee that I am,
Reading the data sheet didn’t help me :)
And btw. if I can get this identified, maybe a newer (simpler) model can replace the complete circuit. ( I understand that identifieng this fist is key :) )
dendad
Joined Feb 20, 2016
4,641
I think it will be a good idea to replace this with a switch mode regulator as this one will be very lossy.
One of the burnt resistors, on the base of the BD249, will be the same as the other base resistor.
As for the burnt collector resistor on the smaller transistor that is mounter up side down, it too could be about 100R.
What does this drive? Is there maybe a 9V or 6V supply needed?
dmtamsen
Joined Jul 15, 2018
12
It drives 12v instruments on my boat. While this circuit has been burnt I have bybassed it with only only instrument directly to the 24v to 12v converter. And That works perfectly.
This is why I am really puzzled.
Dodgydave
Joined Jun 22, 2012
11,395
Thanks in advance.
Dennis :)
This is a simple voltage regulator, with current limit, here is what i think the circuit is , the resistors have burned out and will have taken the transistor also. If you can look at the two transistors faced down and the value of the preset to get a full idea of the circuit.
Personally i would remove it and replace it with a better Buck regulator like LM2596 series
dmtamsen
Joined Jul 15, 2018
12
Personally i would remove it and replace it with a better Buck regulator like LM2596 series .View attachment 156265
WOW - really really nice information and thanks for the diagram, do you have any idea why this is added after the 24v to 12v converter?
dmtamsen
Joined Jul 15, 2018
12
Hi everybody, and thank you so much for this support :)
@dendad you were right from the beginning. My newbee eyes didn’t follow the correct power source, so yes infact it was/is 24v to 12v apparently I have two step down converters both of them using bd249a types
@Dodgydave thank you so much for the diagram it helped me to understand that I most certainly have made some assumptions that wasn’t correct :)
Your recommendation to change to a buck converter is this still true if we have autopilot circuit nearby. I have read something about noise emiting from buck converters.
Everyone else thanks, I already love this forum, the level of support is fantastic:)
ebp
Joined Feb 8, 2018
2,332
I would be very cautious with low-cost switchmode convertrs around radio or other sensitive equipment. Most of those I've seen have nothing for radio frequency interference suppression. Something from a reputable name-brand manufacturer would likely be OK, but I'd stay well away from ebay sources.
dmtamsen
Joined Jul 15, 2018
12
Understood any suggestions, I need 24v to 12v :)?
dmtamsen
Joined Jul 15, 2018
12
What is the current rating u need?
@R!f@@ I need it to support my 12v instruments from my 24v powersource - and I need enough amps available to change different devices at the same time - if this means I need more than one then buck converter then OK - i have the space for it :)
by charging i mean, able to change different mobile and tablets from an normal car socket to usb plug.. makes sense?
