What is this component?
MisterBill2
Joined Jan 23, 2018
27,522
The piezo transducers are interesting devices and they work the other way, as microphones, also. Bond it to a door and it will hear a knocking, giving you a small voltage. Bond it to window glass and hear all the sound on both sides. Of course you do need an amplifier.
raphyy
Joined Aug 4, 2018
6
Interesting!! Do you know why would they use 2 in a microwave? Do they have a different purpose or simply doubling the output?
ebp
Joined Feb 8, 2018
2,332
It may just be that it was easier (meaning cheaper in consumer electronics) to use two than one. If it beeps when you press keys, you would typically want that beep to be fairly quiet, whereas the come-and-get-it announcement you usually want to be fairly loud. Usually the unmounted type aren't as loud as the mounted type.
MisterBill2
Joined Jan 23, 2018
27,522
My first guess is that the two give different tone frequencies.. If they did not have some enclosure or mounting, then it may have been just to produce an adequate sound level. But most likely one was for the softer sounds with each key press while the other was to announce the end of the heating time.
Tonyr1084
Joined Sep 24, 2015
9,744
Interesting thing about Piezo's - they have a preferred frequency much like a crystal oscillator. Piezo's have been used successfully in speakers (tweeters), so they can cover a wider range, but at a certain frequency they will oscillate at their natural resonance and produce the strongest sound they can. Two of them suggests to me that maybe one is for a different tone from the other. Now I gotta run and push buttons on my microwave. No guarantee mine has dual piezo's.
Interesting! Mine has one tone for both the button push and for the alert (end of cook cycle). I hit the wrong button and it gave me an entirely different tone telling me I need to indicate what kind of food I'm putting in. Of course I'm in a hotel, so I can't just open it up and see. But imperial evidence seems to suggest mine MIGHT have two different tone generators.
