Thanks for your fast reply and welcoming me on this forum.Welcome to AAC!
According to a SMD marking index https://smd.yooneed.one/... Possibly
X0Y
R3119N090A
Ricoh
SOT-23-5
Voltage detector IC
9.0V±1.5%, -Reset ODO
XO
2SK209-O
Toshiba
SOT-23
FET n-type
GP, 50V, 10mA, 150mW, Idss=0.6..1.4mA
4700 marking on the resistor indicates it's a 470Ω resistor, not 4.7KΩ. The last digit is a ten's multiplier. Since the last digit is zero then it is not multiplied. Just the 470 indicates the resistance. Or to explain it another way, the last digit indicates how many more zeros to add to the first three numbers. A 4.7KΩ resistor would be marked 4701, the "1" indicating the number of zeros to be added to the first three digits.View attachment 190948
Looks like current is to be applied to the base of the transistor with the help of 4,7 kOhm resistor and therefore a bigger current will flow to power the PC fans.
Looks like current is to be applied to the base of the transistor with the help of 470 Ohm resistor and therefore a bigger current will flow to power the PC fans.
