What is this circuit doing?
Ylli
Joined Nov 13, 2015
1,092
A little circuit that generates +18V from the power transformer in a NAD C375bee Amplifier. Why the complicated circuit just to generate the +18 volts? What is it doing different than an simple rectifier/filter? Does it have a faster/slower rise time? Faster/slower decay? Sure doesn't seem to regulate at +18 too well, but the designer must have done this for some reason. Attached schematic snippet from the NAD manual and my .asc.
Papabravo
Joined Feb 24, 2006
22,116
Depends on what is on the other side of the connector -- THAT YOU NEGLECTED TO SHOW US!
PS I don't usually download files.
Ylli
Joined Nov 13, 2015
1,092
The connector that is labeled "From Main Transformer" is from the main transformer. Pins 1 & 2 are the ends of the winding, and pin 3 is the CT. The "+18out" from the circuit eventually feeds the input to a +5.2V regulator. The manual for the NAD is available here (see page 58): https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=2ahUKEwitq-Pnp4jlAhVHF6wKHYq9BTUQFjAAegQIABAB&url=https://www.manualslib.com/manual/1397194/Nad-375bee-C.html&usg=AOvVaw01dTajUliHr98reZ66Zseo .
Jony130
Joined Feb 17, 2009
5,601
They do it probably to reduce the power losses in the MOSFET. Add the load resistance to your simulation and plot to see it by yourself.
Ylli
Joined Nov 13, 2015
1,092
That wouldn't explain why a simple rectifier/filter with simple regulator would not be used.
I did try with a load, and the output voltage is very load dependent. That's why I mentioned it did not regulate at +18 too well.
Jony130
Joined Feb 17, 2009
5,601
That wouldn't explain why a simple rectifier/filter with a simple regulator would not be used.
Becouse a simple rectifier/filter will produce a high "DC voltage", from 36V AC voltage we will get around 50V DC voltage that we need to drop across series pass transistor. And this "pre-regulator" will help reduce the power losses.
Jony130
Joined Feb 17, 2009
5,601
It looks like this +18V is going into Darlington Q206/Q207 (series pass transistor) which creates the +12VD (input selector relay supply voltage).
Ylli
Joined Nov 13, 2015
1,092
Yes. During standby, the switching power supply is operating and providing +4.65 volts to the MCU. When operating, +12 is feed to the 7806 regulator and that feeds the 5.2V bus. What was happening is that the processor was resetting during that switchover.
