What is the wrong in my circuit
Bamerni
Joined Jun 26, 2016
53
Hello again
I connected a subtractor (difference) circuit and it was worked correctly when I was connected constant DC voltage supply to their inputs
The problem appeared when I connected a TTL signal source
The output is wrong and constant
The aim of my circuit is to subtract a constant from my variable input
Please can anyone tell me the mistake in my circuit
note I tried both 741 and LM358 op amp
Bamerni
Joined Jun 26, 2016
53
You have the op amp plus and minus inputs backwards.
The way it is shown gives positive feedback and thus latchup at the output.
But this is the subtractor circuit as shown in references
So, what do you suggest to do to overcome this problem
#12
Joined Nov 30, 2010
18,224
A simulator showed the wrong result. You asked for help. You received help. Two other experts agreed. Quit believing your references after three experts and a simulator showed you that your reference was incorrect.
ebeowulf17
Joined Aug 12, 2014
3,307
As an op-amp noob myself, I was surprised and disappointed to find that there's no standardization whatsoever in how op-amps are shown in schematics. I had a lot of head scratching confusion until I realized that I just have to check the plus/minus signs very carefully for every input (power supply and signal) every time. As long as I do that, I have pretty good luck now!
To sum up, I totally understand how the thread starter got confused on this, but I'm pretty sure it's time to trust the experts and just swap those inputs!
