What is the voltage across a capacitor?
wmodavis
Joined Oct 23, 2010
739
There is a formula for that. Do you know what it is?
A key piece of information that will help you is the definition of Time Constant.
charmcaster
Joined Jan 13, 2015
22
I google n get, after the first interval, the capacitor voltage equals 63.2% of the battery voltage. so answer I got is 63.2. Is it right?
35,174
Five time constants is not the correct answer (but is a good answer if you supply an error criteria). See the answer given by wmodavis.
As an exercise, calculate the percent error from fully charged for n time constants (for n = 1 to 10).
What is the error for n = 5 and n= 6?
MrAl
Joined Jun 17, 2014
13,791
It is interesting how this changed a little over the years. Way back when, 5 time constants was a good enough approximation because it came in very close to the full supply voltage (cap charging through resistor powered by voltage source). But today with the never ending question for resolution and accuracy, that may not be good enough. Back then most measuring instruments could not detect a 0.7 percent difference, or at least it didnt matter that much. These days with high resolution ADC units we probably want 0.5 percent or better, usually better, and with an RC filter somewhere in the input circuit the time we have to wait before we get a good reading (acquisition time) has to be increased.
38,803
I would think the capacitor can be considered effectively fully charged when it is within the capacitor's intrinsic thermal noise level (√kT/C) of the charging voltage. :rolleyes:
charmcaster
Joined Jan 13, 2015
22
Thanks! error for n=5 is 99.3%
