What is the theoretical concept to shunt RF signal?
dante_clericuzzio
Joined Mar 28, 2016
246
I am not quite understand how the microstripline which is divided by dielectrical material to connect between the signal and ground....how does it really works and why is it able to keep signal stable?
Secondly how do they lock certain frequency in a circuit for example 2.4 Ghz?
Thirdly why do they need buffer in case cases is it to allow the signal build up before releasing to create the shunt wave?
Papabravo
Joined Feb 24, 2006
22,115
The geometry of a stripline provides a distributed series inductance and distributed shunt capacitance. It forms an impedance controlled transmission line from a source to a load. Would you rather use sections of coaxial cable to connect subsystems on a board. You could do it but it would be a pain (ITA).
SLK001
Joined Nov 29, 2011
1,549
Microstrip does nothing to keep the signal stable. There are plenty of unstable μstrip circuits.
μstrip is designed using the main frequency wanted - although some μstrips are resonant, they do not lock onto that frequency.
Like crutschow says, buffers are used to isolate (buffer) on part of the circuit from another. As for the rest of your question, I have no idea what you are talking about. What is a "shunt wave"?
dante_clericuzzio
Joined Mar 28, 2016
246
Can we just use two inductors where one is to transmit and another to receive...between is air (no diaelectrical material) to connect the two its just received by the second inductor through wave transmitted to the air by the first inductor
Papabravo
Joined Feb 24, 2006
22,115
Depends on the frequency. Traditional air core inductors don't work well in the GHz. frequency range.
dante_clericuzzio
Joined Mar 28, 2016
246
There is one strange behavior that i notice from the air core experiment ...using the active crystal oscillator and it goes like this.
Using 20 Mhz crystal oscillator to generate the frequency and goes through the air core inductor and then using frequency counter to measure the frequency at the output end it read 20 Mhz which is logical....but..when i measure the frequency on the a certain distance away from the inductor for example 5 cm away (not touching the inductor) it reads around 1.5 Ghz...if goes further distance the frequency is going down and goes away...and when getting closer to the inductor it gradually goes back to 20 Mhz..
Now my question is why at certain distance in this case 5 cm away from the inductor it measures around 1.5 Ghz very very strange..is this why the coaxial or the microstripline does not connect directly between signal and ground and thus using dielectrical material in between?
dante_clericuzzio
Joined Mar 28, 2016
246
Thanks all for the input and ideas - I think i get it how to make the microstripline using an alternative coaxial cable easily :)...i am excited to build the most consistent RF booster for my 4G LTE internet now. Cheers!!! Life is an experiment wooohooo...
My result best i can achieve thus far...i am looking for full 5 bar signal improvement that will consistently run at 90% without going down.
