what is the Schmitt trigger op-amp?
WBahn
Joined Mar 31, 2012
32,929
My guess is that you are talking about an op-amp circuit that is configured as a Schmitt-trigger comparator.
Look up what a Schmitt trigger is and see if that helps.
38,540
In general, a Schmitt trigger is a circuit that has a small amount of positive-feedback that makes the trigger voltage for activating the circuit higher than the voltage for deactivating the circuit (trigger hysteresis).
That makes the circuit immune (prevents it from triggering or oscillating) to noise voltages smaller than the hysteresis value.
MaxHeadRoom
Joined Jul 18, 2013
30,692
@subatomic particle The LM311 comparitor acted as a Schmidt trigger for me used this way.
  1. Schmidt Trigger: a bistable circuit in which the output increases to a steady maximum when the input rises above a certain threshold, and decreases almost to zero when the input voltage falls below another threshold.
Max.
ebeowulf17
Joined Aug 12, 2014
3,307
Max.
Where did you get that definition from? It's unusually vague. Every definition I've read talks explicitly about feedback and hysteresis.
Although the definition hints at the possibility of hysteresis by describing two thresholds, it's somewhat unclear. Further, the illustration you attached shows no hysteresis at all.
I'm no expert, so I could easily be wrong, but I'll say this: Even if the definition and illustration are technically correct, they don't reflect what people expect when you discuss a Schmitt trigger.
38,540
In your posted comparator circuit both thresholds are basically the same.
In a Schmitt Trigger circuit there is positive feedback so that the rising threshold is higher than the falling threshold.
Otherwise there would be no difference between a simple comparator circuit and a Schmitt Trigger circuit.
WBahn
Joined Mar 31, 2012
32,929
Max.
I've got a few problems with this definition.
First, it's not a Schmidt Trigger, it's a Schmitt Trigger, named after it's inventor, Otto Schmitt.
Second, just saying that the second change occurs at "another threshold" isn't enough. If the first threshold is for when the input signal is rising, then the second threshold (for the falling signal) must be at a lower value. This definition would settle for any threshold that was simply different.
Third, this definition requires that the output goes HI when the input signal is high. But that's not required and many Schmitt triggers behave the opposite. The classic op-amp implementation behaves this way because that's one of the simpler ways to implement the hysteresis.
Fourth, this definition insists that one of the output levels has to be zero. There's no such requirement. The outputs can be whatever two levels are desired. Bipolar outputs are quite common.
In addition, as others have noted, the figure is NOT for a Schmitt Trigger, even by this definition. The entire purpose of the Schmitt Trigger requires that the threshold move in the direction opposite the direction the input signal is changing (although an alternative is to augment the input signal to make it move further in the direction it was already moving while keeping the threshold the same).
38,540
Some CMOS Schmitt Trigger logic gates are the CD4093 NAND gate, and the CD40106 Hex Inverter.
The CD4093 is useful to configure as a Schmitt Trigger XOR function when building a low-frequency XOR pulse doubler circuit.
