What is the polarity of inductor acting as a current source when connected to a DC source?
Devika B S
Joined Mar 8, 2017
144
From what I understand, the polarity of inductor is opposite to that of the initial DC source connected to it. For example, indisource.jpg in the diagram above, I hope the current direction shown in mode 2 (the second diagram) is correct and not in the opposite direction. However, while writing equations, this negative sign is neglected as only (del I) is written.
Devika B S
Joined Mar 8, 2017
144
But the current wants to continue flowing in the same direction.
But once disconnected, now the polarity of the inductor being in the reverse direction; the current is supposed to flow in opposite direction (as current always flows from positive to negative). Right? Isn't this how switched mode converters like Buck converters work?
38,912
You might think of the current in the inductor as an inertial mass.
You have to push to get the mass moving, and when you stop pushing, it wants to keep moving in the same direction.
You have to apply a force in the opposite direction to slow it down (similar to the reversed voltage with the inductor when the voltage is removed).
38,912
No and no.
The reversed voltage slows down the current but it doesn't reverse it.
In a Buck converter, the current is always moving the same direction through the inductor.
Devika B S
Joined Mar 8, 2017
144
No and no.
Ok. It only slows down and doesn't reverse the direction. Thanks for the clarification.
