AlbertHall
- Joined Jun 4, 2014
- 12,660
In series with the current that you want to measure. Connect the two leads from the 'scope one to each end of the resistor.
Do you need to allow for the internal resistance of the capacitor? (or the AA battery) Is the resistance of the wiring and capacitor more than that of the resistor? What kind of switch are you using to discharge the capacitor? Does it have a resistance?Does the Super Capacitors have the same principle of charging as of the general Electrolytic or Ceramic Capacitors. Do they also depend on the charging time constant 5RC?
Using a 'scope to measure voltage drop across the current sensing resistor, one termination of the resistor must be connected to circuit ground. Usually circuit ground is also ground of the 'scope which is the reference potential of one of the two connectors of the probe of the 'scope.In series with the current that you want to measure. Connect the two leads from the 'scope one to each end of the resistor.
The current sensing resistor and 'scope is not bad if you want to see the waveform of the current, or when current is drawn relative to a voltage of the circuit. Of course a multi-meter will generally do very poorly at measuring a changing current.There are ways around this but, I agree, measuring voltage with a scope to calculate current seems a bit convoluted - especially if scope is grounded and circuit is charged from mains or a non-isolated transformer.
With a 2 channel 'scope you can usually use probes connected to both channels set to invert one channel and display the sum so you a differential input to the 'scope. Provided the voltage to ground isn't too great this gets around the grounding problem.In the past I remember finding that isolating the 'scope from earth ground would allow measuring voltage drop across a current sensing resistor that was not connected at one end to circuit ground. Do you think that not earthing the 'scope is bad practice? In my case this is the old style cathode ray 'scope.
Thanks for letting us know about this procedure. On my dual trace 'scope, there are the controls that would allow me to use that method.With a 2 channel 'scope you can usually use probes connected to both channels set to invert one channel and display the sum so you a differential input to the 'scope. Provided the voltage to ground isn't too great this gets around the grounding problem.
