what is the difference between these two supplies
ashokraj
Joined Feb 1, 2018
151
I am wondering how will these two differ, One is Ac to DC converter module, second one is SMPS.
Link1(AC to DC module)
Link2(SMPS)
when link 1 is available in a small size than Link2(SMPS). Under what circumstance we have to use Link1 and link2.
I understand that SMPS is 5watt, Link1/Module is 3 watt.
I am looking for the technical differences.
Ian0
Joined Aug 7, 2020
13,310
LInk2 is rated at 5V @ 5A = 25W. That's why it's considerably larger and designed for better cooling.
Ramussons
Joined May 3, 2013
1,572
There will not be much difference between the two, technically.
Link 1 is compact, maybe with the pass transistor built-in into the controller IC.
Link 2 is with external pass transistors.
As mentioned in #2, the difference is mainly the powe handling capacity.
