What is the clock generating diagram I2C protocol while sending Data & Address from mater to slave.
shetsachin
Joined Jul 5, 2017
23
I need to communicate between Micro controller & FPGA(frame grabber card) using I2C protocol.
I want to know if data 5 has been sent from Master (Controller) what will be the clock generation.
Using clock generation i can set frame grabber card as readable.
Is this possible or can we determine the I2C clock cycle generated?
shetsachin
Joined Jul 5, 2017
23
Did you read the document I provided? For example Fig. 6 on p. 10. Do I really need to hold your hand or can you do this on your own.
I know that, the red marked data clock pulse i need to know.
For ex: If i need to send 5 what will be data clock pulse diagram.
I tried in several manuals & application note, didn't get.
Papabravo
Joined Feb 24, 2006
22,111
I understand now. You need to send data in groups of 8 bits because the I2C state machine in the peripheral will send an ACK on the 9th bit. If your data does not require all 8 bits then you pad with zeros on the left. For Example is you want to send 5 = 0b101, the you must send 0b00000101. Do you get the picture?
LesJones
Joined Jan 8, 2017
4,543
My understanding of the significance of the 5 bit question is the TS does not realise that the diagram is just saving space by not showing bits 3 to 8 in full. I don't even know if he plans to use a microcontroller with no hardware support for I2C and so all the work is done in software and just use IO port bits. I used a PIC12F1840 which has a master synchronous serial port which does a lot of the work.
Les.
Papabravo
Joined Feb 24, 2006
22,111
Les.
I've got to admit there was not a great deal of useful details in the original post, and it was certainly short on the actual requirements.
