What is phase current of stepper motor?
nandishJasani
Joined Jul 4, 2023
9
I have stepper motor with me without its part number i.e. i dont know the make and part number of this motor. I have following parameters with it. I have A5976 stepper motor driver controller interfacing with FPGA. In A5976 i have to set the Vref which is corresponding to winding current. So anyone can help from below parameters of stepper motor that what is the winding current and step degree of this motor?
Its Stepper motor Nema 23 (57mm)
Its length is 76mm.
Its two phase motor.
Its winding resistance is 7.8ohms. (Measured with multimeter)
Its winding inductance is as follows (Measured with LCR Meter)
Measuring frequency 100Hz - 48mH.
Measuring frequency 1KHz - 35mH.
Measuring frequency 10KHz - 20mH.
Please help to find this motor parameters like phase current and step degree.
Nandish Jasani.
MaxHeadRoom
Joined Jul 18, 2013
30,813
A common step angle is 1.8° =200 steps/rev.
You can measure this by pulsing one winding with a 4v DC source, one pulse at time.
The typical Va for a NEMA 23 would be between 7 and 10 Va. with 76mm putting it at ~9Va to 10Va.
Estimated.
BobTPH
Joined Jun 5, 2013
11,655
The parameters should include the phase current. It is not something you can determine.
The voltage required to achieve that current depends on how fast it is running. When stopped (holding) it is simply the current times the winding resistance.
28,322
Consider that the resistance is what determines the winding current in a stepper, that is used as a stepper motor, while the inductance determines the applied voltage and series resistor to deliver the needed maximum speed, although this system probably uses PWM to control current and torque.
The step angle is easily found by turning the motor by hand and counting the number of resistance torque steps in one revolution. Then the step angle is 350 degrees divided by the steps per revolution. Stamped case steppers vary in the number of steps per revolution.
Ian0
Joined Aug 7, 2020
13,279
You can find the step angle by shorting out one winding, then turning thr shaft by hand until it completes a full turn. Each click is four steps. 50 clicks indicates it is a 1.8° motor.
Phase current can be determined by calculating I^2.R for a similarly sized motor to determine its maximum power dissipation then working back to give Imax for your motor. It will only be an approximation, as you do not know whether the maximum insulation temperatures are the same.
panic mode
Joined Oct 10, 2011
5,275
one way to determine number steps is to run it... send pulses until it completes revolution. about current that motor will handle - who knows. you need part number and datasheet. if unsure run it at lower voltage. increase voltage as practical. of just get new motor. no-name parts are not worth it unless you are willing to sacrifice them - or use them conservatively.
Ian0
Joined Aug 7, 2020
13,279
If you don’t have stepper motor drive circuitry to hand, you can run it as a capacitor run motor from a low voltage transformer.
A 1.8° motor will go round once a second on a 50Hz supply.
MaxHeadRoom
Joined Jul 18, 2013
30,813
I still have a few stepper manuf. literature from decades ago and they show the max temp of the centre of the frame should not exceed 100° C. for any stepper.
Most drives now use a translator circuit/IC to maintain the motor rated current throughout the RPM range.
e.g. L297 etc.
28,322
Max is correct. The series resistor scheme was common bck in the early 1980's era. Now PWM control does a better job and is vastly more efficient.
nandishJasani
Joined Jul 4, 2023
9
Thank you so much all
This discussion is helping me and i gave 200 pulse and motor rotates 360 degrees i.e. it has 1.8 Degree resolution. And for current i limit it to 1Amp and it works fine.
Regards,
28,322
The final check for the current limit setting is to feel the motor after it has been in use a half hour. If it is too hot to be touched then the current limit is too high. Usually this is a simple and easy check.
MaxHeadRoom
Joined Jul 18, 2013
30,813
Oriental Motor suggest using a thermometer at the centre of the motor body held in place affixed with thermal putty or other means and test for temperature to not exceed 100 °C. after an extended period of use.
