Many opamps have transient and/or reverse polarity protection diodes at the inputs. Some have a linear input common mode range that extends down below the part's negative rail (GND, -V, whatever). In general, I think it is safe to say that a few millivolts of reverse boas won't do any damage no matter what the input stage looks like. But for a low impedance, higher voltage source, you are correct - the negative currents might cause damage unless dealt with.I would've thought you couldn't feed a ground-biased AC signal into a single supply op amp because you don't want the negative component of the AC hitting your op amp input.
Is this treated as ok here simply because the microphone's signal will be too small to do any harm? In other words, you wouldn't set an op amp up as a half wave rectifier the way you described if the AC signal was several volts, right? It's only ok because we expect the signal to be small fractions of a volt. Or am I missing some other reason why this is acceptable?
ak
