What is a 7/10" #14 Hairpin Inductor?
bertus
Joined Apr 5, 2008
23,036
Are you refering to the 6 watt broadband amplifier?
Here I have taken some picturs of an other amplifier with different syles of hairpin coils.
The following one shows the thick wire hairpin as in your wanted schematic:
The other two pictures shows the hairpin made out of strip material:
The pictures are taken here at home.
doug08
Joined Jan 30, 2011
153
I made that circuit, it works, but not really good. I only had a 2-3 watt fm transmitter to try and amplify. When I connect the transmitter to the RF amp with the known good tuned antenna, it only draws between 0 - 150 ma. This seems like nothing for 6 watts. The output also is 1 mhz off from the transmitter output frequency. I have a small transmitter that is between 100 and 300 mw....it does no amplification at all on those. Does my circuit look ok?
Thanks.
