Open circuit voltage is a few hundred - emf from breaking current may well be in the order of a few thousand. Transistor assisted contactors don't have to put up with that.I would expect it to be in the region of a few hundred but have never tested it.
No, shorting the windings to ground does not create the high voltage spikes as the magnetic field is not collapsed, which is what happens if you open the circuit.
I expect the Series regulators will have some form of TSV protection, either that or it's FET's are rated to survive the spikes, the problem with this is the spikes are still created and the stators' own insulation will not be rated to that voltage level.
