What happens if two linear optocouplers are paralleled, if their output voltages are different?
johnyradio
Joined Oct 26, 2012
615
If the outputs are connected, what voltage would be detected at the combined output? The higher voltage? Or, would the lower voltage device malfunction in some way?
Since they are optically isolated, i think it's not possible for one output to feed into the other output.
There would not be a load on the combined outputs.
Example part: FOD2712A - Optically Isolated Error Amplifier
https://www.mouser.com/datasheet/2/308/1/FOD2712A_D-2313415.pdf
Something is wrong with this sim, but i don't know what. Getting "convergence failed".
http://tinyurl.com/yotdpz9r
34,717
Your simulation is meaningless. You have no load on the outputs.
You need to put a load resistor, for example 5kΩ to a positive voltage source, for example +5V.
Also, you need current limiting resistors on the emitters.
johnyradio
Joined Oct 26, 2012
615
Not sure if this is what you mean. Not getting an error anymore.
http://tinyurl.com/yo5te6r8
But i think the key is to put diodes on the outputs to prevent backflow.
Ian0
Joined Aug 7, 2020
13,123
Just put them in parallel with a single pull-up resistor.
The output of an optoisolator is a current that it proportional to the current through its LED.
So the voltage across the pullup resistor will be V=(Iin1*CTR1+Iin2*CTR2)*Rpullup.
johnyradio
Joined Oct 26, 2012
615
You mean the R as shown in my reply above?
BobTPH
Joined Jun 5, 2013
11,492
Collectors both connect to one side of pullup. Other side of pullup connects to +5V.
Emitters of the transistors both connect to ground.
Ramussons
Joined May 3, 2013
1,568
An Opto Coupler is not a Voltage Source, it is a Switch. Connecting 2 in Parallel will make it behave as a OR gate triggered by light.
BobTPH
Joined Jun 5, 2013
11,492
Actually it is more of a current sink. Within some range, two linear optos in parallel will add their effects.
