No you are right EMF means electromotive force Its the same as voltage but emf is usually used for batteries and voltage is used to describe the voltage drop on resistors or whatever.i know it has to do with electro magnets and motors and dynamos but i dunno wt it means... i thought it was electro motive force but apparently im wrong
So is it wrong when people use it for electrmagnetic force? I constantly see people use it that way. Is it just a matter of opinion or something?No you are right EMF means electromotive force Its the same as voltage but emf is usually used for batteries and voltage is used to describe the voltage drop on resistors or whatever.
yay so it is good. tnks and you casn close this threadNo you are right EMF means electromotive force Its the same as voltage but emf is usually used for batteries and voltage is used to describe the voltage drop on resistors or whatever.
No its not wrong as you know what are you doingSo is it wrong when people use it for electrmagnetic force? I constantly see people use it that way. Is it just a matter of opinion or something?
actually im studying for my matsec examination to get the o.level degree. the exam is in 2 daysNo its not wrong as you know what are you doing
