- Joined Jan 23, 2018
- 28,626
I repaired a "burned out" Simpson model 720 ammeter package. If was really cheap because the seller said that the meter "must be fried, because it does not move at all". But since it still had an internal current transformer and four nice terminals it was worth what I paid for it.
I measured across the ten amp range terminals and it read open.
I opened the case and checked the meter resistance. less than an ohm.
So I decided to check the range switch to see of that was the problem. The range switch selects either the ten amp terminals or the 200amp current transformer or off. It is a heavy-duty 3 position-center off double pole toggle switch. No continuity between any terminals in any position. That was the problem. I did not open the switch, I shot quite a bit of contact cleaner in next to the toggle lever. After several shots and a lot of exercising it, IT WORKS!!!
Given the age, my guess is that the electrical grease inside had solidified and formed an insulating film.
Not the simplest repair ever, but certainly in the running for an easy repair with an incorrect initial diagnosis .
AND A Good deal as well. Now I need the instruction book.
