The resistor value must absorb the excess voltage at the required current flow.The resistors I have are 150 ohms. Will those still work for option 1?
The sum of Vf must be less than Vcc. The finer you cut it; the lower the resistance has to be. A low resistance will waste less power, but it will be less tolerant of supply voltage variation.
