Hi friend. I have a problem with a tumble dryer. 712529-01 electrolux 0102_0004B
At first it does not turn on, I open it and find a large resistor with a small black spot on it.
Behind it (after I take it out) I see it is 47r 10%.
I have no such resistor but I insert a resistor with values 56r.
After that it does not work yet.
After googleit I understand that LNK304GN that is Off-Line Switcher IC link switch.
I buy it soldaring it, and its start works, the lights come on and make noise properly and everything works fine. After that one day it does something very strange.
When I put it on the power and turn it on it does not work, the lights do not turn on and do not work, just noise from the speaker.
Such variable noise.
If one of the company here has an idea why there might be a particular problem or direction.
I would love to hear thank you so much Friends Champions Thank you!
https://imghub.io/i/0zfoJ
https://imghub.io/i/0zb71
https://imghub.io/i/0zkXH
https://imghub.io/i/0z04k
https://imghub.io/i/0ztwy
