AlbertHall
- Joined Jun 4, 2014
- 12,640
This item has internal drive circuitry and requires only DC to function (of the correct polarity). It follows that it will only operate at its design frequency.
Sorry, I have multiple buzzers now. This is the one I'm talking about:This item has internal drive circuitry and requires only DC to function (of the correct polarity). It follows that it will only operate at its design frequency.
The datasheet for that gives no clue about the frequency response other than resonance at 2048Hz. It follows that the response at other frequencies will be lower but only a guess or an experiment will determine how much lower. It isn't designed to have a wide frequency range, so unlike a loudspeaker.Sorry, I have multiple buzzers now. This is the one I'm talking about:
Tayda Electronics - ELECTROMAGNETIC TRANSDUCER 1-2VDC 30MA PCB 2 PINS
This seems unlikely. The wavelength of 2048Hz in air is about 16cm. http://www.1728.org/freqwavf.htmif its enclosure size is also resonant at that frequency.
