Weather Station remote sensor temperature correction
CrustyS
Joined May 20, 2019
27
I have a radio controlled weather station which has always shown 2°C less than the environment in which it is placed for the remote sensor, verified by good quality mercury thermometer and a couple of other systems I also have.
I particularly like this station as it shows sun rise/set and moon rise/set for my city and the overall data presentation is quite good. So I decided to try and improve the accuracy.
The remote module uses an NTC for temperature so my first step was to remove this and do a calibration curve. I recorded 10 points from 5°C to 35°C and did an X/Y plot with Excel. Data shows linear relationship with R² of 0.98 which is a pretty go fit. The NTC value for 25°C is 44K which is little odd but could be a custom sensor.
Looking to my data set a 2°C increase would need a reduction in resistance of 3K (I wonder if the software is expecting a 47K NTC as mine 44+3 would be 47K coincidence ?).
I think the measurement is using a voltage divider.
Calculating a resistance in parallel I need to get the 3K reduction I get 1 Meg ohm, or so I think.
I would be most thankful if some one with more knowledge could cast an eye I over what I have done and point out any mistakes or erroneous assumptions I have made before I start soldering.
I haven't posted the data but if any one is interested I will.
TC
35,319
TC
Please post the data.
I don’t see much harm in trying your 1MΩ hack. Try it and see the effects.
CrustyS
Joined May 20, 2019
27
Update.
I reattached the NTC and added some extension wires so I could try different resistances. First one 1 M ohm only gave 1°C increase, half of what I was expecting. I then changed this for a 1.5 M ohm potentiometer and adjusted it down from 1.5 M slowly allowing for the value to settle. I was rather surprised that the highest value was actually a little lower than the 1 M fixed resistance I had tried. I continued to reduce resistance and the "measured temperature" increased until I reached the +2°C I was looking for. The resistance was way less than I had anticipated and measured 495K when detached from the circuit. I used a fixed 500K next and this confirmed the +2°C. Hmmm.
Last experiment was to put the pot back in the circuit and wind it down further. The temperature duly increased but in a non linear fashion and hit "HH" at minimum resistance.
I guess my assumptions about he voltage divider were wrong. Any insights are most welcome.
TC
Alec_t
Joined Sep 17, 2013
15,171
Putting a fixed resistor in parallel with the NTC can correct the reading for one particular temperature, but not for the whole range.
35,319
Try finding the parallel resistance required at 25°C.
Then find an NTC thermistor at that value and use that in parallel instead of the fixed resistor.
CrustyS
Joined May 20, 2019
27
Final update.
I ordered some mixed value NTC's and did a little experimenting and found that a 300K ohm NTC in parallel gave me the offset I needed and was 1.7 - 2.0°C from 5-30°C, I was looking for 2°C.
Thank you to all those who helped and especially to MrChips
35,319
Final update.
Thanks for the update and acknowledgement. It is always appreciated when a member responds with a final update.
