We have a code for our fpga project we need you to modify the code to run run in basys 3 and the outputs will be given in the computer.
vasanth2304
Joined Mar 5, 2024
4
Mod: added Code quotes.
C-like:
module image_overlay (
    input clk,
    input rst,
    input [7:0] image1_data, // assuming 8-bit grayscale image
    input [7:0] image2_data,
    input [7:0] overlay_mask, // 8-bit mask for overlaying
    output reg [7:0] combined_data,
    output reg vsync,
    output reg hsync
// Define image dimensions
parameter WIDTH = 320; // assuming 320 pixels width
parameter HEIGHT = 240; // assuming 240 pixels height
// Define counters for tracking image positions
reg [9:0] x_counter;
reg [9:0] y_counter;
always @(posedge clk or posedge rst) begin
    if (rst) begin
        x_counter <= 0;
        y_counter <= 0;
        combined_data <= 8'b00000000; // initialize combined_data
        vsync <= 0;
        hsync <= 0;
    end
    else begin
        // Increment counters
        if (x_counter == WIDTH - 1) begin
            x_counter <= 0;
            if (y_counter == HEIGHT - 1) begin
                y_counter <= 0;
            end
            else begin
                y_counter <= y_counter + 1;
            end
        end
        else begin
            x_counter <= x_counter + 1;
        end
        // Overlay logic
        if (overlay_mask >= 128) begin // if mask pixel is white (or close to it)
            combined_data <= image2_data; // overlay image
        end
        else begin
            combined_data <= image1_data; // otherwise, use base image
        end
        // Output synchronization signals
        if (y_counter == HEIGHT - 1 && x_counter == WIDTH - 1) begin
            vsync <= 1;
            hsync <= 1;
        end
        else begin
            vsync <= 0;
                hsync <= 1;
            end
            else begin
                hsync <= 0;
            end
        end
    end
end
endmodule
Ya’akov
Joined Jan 27, 2019
10,356
Welcome to AAC.
While you’ve posted your question to the correct forum (since it is an assignment) your question is not acceptable.
As you should have learned from your last post, the rules of AAC only permit assistance with your work, not to do it for you. Please post your attempt to solve the problem, we can then help with guidance to make it work.
[MODERATION]
