I am looking for a circuit diagram whcih will acheive a similar result to these products:-
https://www.adafruit.com/product/2133
https://www.adafruit.com/product/2220
Is anyone here aware of an open source circuit diagram which will achieve the same result as these products, but at a significantly lower cost? I am happy to do any assembly and/ or embedded programmign in C if that is the most cost effective approach.
The features I need are:-
- Built in Flash storage - 16MB ideally
- Built in Mass Storage USB
- 44.1KHz 16 bit stereo wav file playback
- Stereo line out
Power will ideally be from a 9v source, powering multiple units
The idea being that I can copy a .wav file from a PC directly onto the unit, and then trigger the audio playback - probably using a piezo.
I need 20 such boards for a project, and $400 - $500 is prohibitive
- Stereo line out
