Wattage in voltage devider
ISB123
Joined May 21, 2014
1,236
M3 is world standard for bolt size. They should know what bolt you want.
I'm going to post the schematics for lm317 and explain how it works when I get on the computer.
Chillum
Joined Nov 13, 2014
546
317 1.5A; 350 3A why not the 350 then, seems everything else is the same except the 317 is 1.2-37V 1.5A and 350 is 1.2-33V 3A both cost almost only the petrol for the journey.
38,746
The tolerance of the regulator reference voltage will also give some variation in the output voltage from the ideal, even with exact resistors. If you want exactly 5V then you can use a pot (connected as a rheostat) for one of the resistors, but note that 5V circuits are typically designed to operate properly with +/- 5% tolerance on their supply voltage.
bertus
Joined Apr 5, 2008
22,995
Here is a tip for mounting the TO220 isolated, as the tab of the device will be connected to the middle pin.
The grid on the picture is 5mm, to have an idea of the size.
As you can see the black ring has a rimm that goes into the hole of the TO220 device.
(shown in the picture is an old transistor).
Bertus
ISB123
Joined May 21, 2014
1,236
Here is a very basic explanation of the circuit.The explanation is pretty basic since you probably know what capacitor and similar passive parts are.If someone has more time to make it more detailed i'd be glad if they could hop in and explain it a bit better.
studiot
Joined Nov 9, 2007
4,998
I can only get 220, so R2 680 = 5.114 That'll obviously also do.
That will not do for TTL logic circuitry.
You need the +5 volts to be as exact as you can make it.
TTL is more sensitive to overvoltage. 5.1 is within range but too close to the TTL range of 4.75V - 5.25V supply.
Further the 5V provides the reference level for the logic pulses.
By contrast the CMOS voltage range is +3V to +15V
This is a good opportunity to practise your series and parallel skils to get your resistors closer in combination, though most practical people would use a trimpot and set the final value to give correct output with a voltmeter.
bertus
Joined Apr 5, 2008
22,995
The use of a trimpot will be needed, as the LM also can have an other reference voltage (between 1.2 and 1.3 volts).
Also check the datasheet if you need a resistor of 240 Ohms or 120 Ohms from the output to the reference pin.
Bertus
