Want to make an Electromyography amplifier circuit
AlbertHall
Joined Jun 4, 2014
12,663
You will need to connect the ground of your circuit to the arduino ground.
You may also need a resistor across the output as with no resistor the voltage on C5 will no fall when the input falls. You will need to set a time constant suitable for the signal.
Abhishek Dhiman
Joined Oct 20, 2017
40
Hello sir can i use AD620 in place of INA106?
How to make a dual voltage supply?
Please tell me about the supply for AD620 and the ground
