Wanna see something cool #2
Tonyr1084
Joined Sep 24, 2015
9,744
Has anyone used electrostatic air movement instead of ducted fans for propulsion like the ionic breeze machines?
Welcome to AAC.
To answer your question; No, I don't think so. Ducted fans or propellers for lift generate much more lift than electrostatic air movement. I can't imagine how big it would be or how much power it would need to lift any kind of serious weight.
strantor
Joined Oct 3, 2010
6,875
I wasn't sure what I was seeing at first but reading through the comments helped. Apparently the stator is on bearings, allowed to spin freely as the motor starts up. Once the stator reaches synchronous speed, they start tightening a brake/clutch which slows the stator, transferring torque to the rotor. Once the stator stops spinning, the rotor is then at synchronous speed and driving a load.
strantor
Joined Oct 3, 2010
6,875
Was that intentional? Or did a motor fail? If it was a failure then the pilot is darn lucky it didn't happen at a lower altitude. But it's pretty cool. As long as you're not over water that is. Or over high power lines or over train tracks.
I think it was a test
Tonyr1084
Joined Sep 24, 2015
9,744
While wasting time watching useless video's on YouTube I came across this. In answer to your question;
I replied:
Welcome to AAC.
But then I found this:
I still think a practical application would incorporate so much weight that it may still be not worthwhile to build.
I replied:
Cool but as useful as human powered flight.
ThePanMan
Joined Mar 13, 2020
950
Useful if you're a professional cyclist. But forget about bringing home a gallon of milk. MAYBE a loaf of bread. But in either case I'd rather walk. It's only 1.5 miles to the store and another 1.5 back. 3 miles round trip - no big deal.
