voltage Stability factor of voltage regulation circuits
Jamiel5600
Joined Jan 19, 2021
3
Here a shunt voltage regulator circuit with two zener diodes
One zener diode Z give the reference voltage at the comparator for the feedback signal .
But I can't explain the role of the second zener diode Z1
I've to calculate Voltage Stability factor (Sv) .
Any Suggestion is welcome.
AlbertHall
Joined Jun 4, 2014
12,640
Without Z1, the current through zener Z would change as Ui changes and so produce some change in the reference voltage.
Z1 keeps the voltage at the junction of R1 and R constant(ish) and the voltage across R will change less when Ui changes and so the voltage across Z will be more constant.
Jamiel5600
Joined Jan 19, 2021
3
Thank You Albert Hall
if i've well understood , i will say that Z1 must drain overcurrent caused by the increasing of U1 to maintain the voltage at the node of the junction R-R1 constant ,
How to turn this into equations between U1 and U2.
AlbertHall
Joined Jun 4, 2014
12,640
That's your exercise for today!
Jamiel5600
Joined Jan 19, 2021
3
For Example for the feedback through Ra-Rb potentiometer ,
we have Vb of T1 => Vb1=( Vz - Ib1 r1) and Ve of T1 => Ve1=( V2( Rb/Ra+Rb))
T1 conduct if Vbe (T1) >= 0,7 so we have Vbe(T1) = (Vz-Ib1*r1) - ( U2*(Rb/rb+Ra)) = 0,7 (0*)
let consider the figure below
if you follow the green line we have
U2 = Vz + Ib1 *r1 + Ic1* r2 (1*)
if you follow the red line and uses the MILLMAN Formula ( V = ΣViGi / ΣGi )
we have
Vz = (Rz1*Rz *U1 + R1* Rz*U2) / ( R1*Rz1) + (R1*R) + (R1*Rz) + (Rz1*Rz) +(Rz1*R) (2*)
if you replace the expression of Vz given by the second equation (2*) into the first equation (1*) , i have my relation between U1 and U2
But i've to calculate Ib1 , and for this i'm feel lost
But i think that we could use our first equation (0*) to eliminate Ib1 in our system Equations
given by
To Be continued .........Please
